I've not quite figured this out yet, my new truck has those manual locking hubs fitted, I'm a little confused on there benefit, a Google search suggests to me that they lock the wheels to the axle, is that the same as locking the diff?
Quick question for off roaders
Originally posted by AlexKzn130 View PostI've not quite figured this out yet, my new truck has those manual locking hubs fitted, I'm a little confused on there benefit, a Google search suggests to me that they lock the wheels to the axle, is that the same as locking the diff?
Manual hubs allow the wheels to "freewheel" under normal driving conditions, reducing wear and tear on the CV joint and front diff, also "potential" for an extra MPG or 2.
If you go off road you need to lock the hubs to "attach" them to the drive shafts, If you do then need to engage for wheel drive the front diff will turn the shafts and wheels at the same time.
If you leave them unlocked, you only end up driving the shafts from the diff and are still in two wheel drive.
Hope this helps.
Andy
Hope this helps.
Andy
CheersYes it's a V8, don't you know I'm loco?
This may help explain ....
http://pitstop.oncourse4wd.com/2003/...ng-phenomenon/
15+ Years of Surfs .... n Faultless to a "T" is my Yota !! So I got another ....Buncefield Burner
The stock Surfs have a splined flange bolted to the hubs, which connect to the splines on the drive shafts. As stated above manual hubs allow unlocking so the drive shafts and CV are not turning all the time. Always lock hubs before using 4WD.
Nev.
Originally posted by NiftyNev View PostThe stock Surfs have a splined flange bolted to the hubs, which connect to the splines on the drive shafts. As stated above manual hubs allow unlocking so the drive shafts and CV are not turning all the time. Always lock hubs before using 4WD.
Nev.Yes it's a V8, don't you know I'm loco?
Originally posted by budweiser View Postyou are lucky you got them, im looking for a pair of those, where do you normally park?
As of tonight I'll be parking in the back of a police station lolYes it's a V8, don't you know I'm loco?
Originally posted by marky View PostDecent A/T Tyres are your 1st modificaion for offroading the rest can wait a while as the Surf is very good offroad
Hey marky long time, hope ya made it back up the ladder n are ya still Surfing
these days ?
If you have an open diff (not LSD) and want to have more traction with RWD only, look into an auto locking rear diff:
http://www.powertrax.com/index.php/products/lock-right
I have one in my Surf and think it's one of the best mods I've done. I think it also saved my mum a few weeks ago when she took a wrong turn on private property and ended up on some boggy grass trying to back out. Got into trouble for having ruined the grass but didn't get stuck. She forgot about the manual hubs.
I ended up paying 160 quid for the unit and 100 quid shipping from USA back in 2010.Oh Nana, what's my name?
Originally posted by dieselboy View PostIf you have an open diff (not LSD) and want to have more traction with RWD only, look into an auto locking rear diff:
I ended up paying 160 quid for the unit and 100 quid shipping from USA back in 2010.Yes it's a V8, don't you know I'm loco?
If it's factory standard then the front will be an open diff. You probably don't want an LSD in the front as an LSD is there to try and restrict or prevent the wheels from turning at different speeds on that axle. And the front wheels will always turn at different speeds unless you're going in a dead straight line
Toyota LSDs are known to be a bit on the weak side from what I found so if you fit bigger tyres, you might probably find one wheel spinning and a little bit of power going to the wheel with grip. That was my experience anyway
You have an SSR G with the fishnet Recaros? I still think theyre more comfy than my 2015 bmw. Theyre not comfy to sleep in whatsoever though!
Same Recaros as an Escort RS2000 - I'm surprised my truck hasn't been broken into over night and the front seats stolen TBH.Oh Nana, what's my name?
