Evening all,just got in from trying to sort out my starting problems, think i have got it sorted(leaking fuel pipe).While trying to find the problem I've changed,ECU,Glow plugs,Both glow plug relays and 80 amp fuse.The only way to get it started was with a little misting of easy start and she would run fine.Just to make sure glow plugs where working as thay should I hooked a led light to the buzz bar,this is what happened,full power click of relay then half power as it should, now the thing is the light never went off even when up to temp, why would this happen?is it controlled by the resistor under the manifold or block temp sensor (which is all so new). Many thanks up front ....Mick
