Have any of you chaps had a problem with your rubbers?. No, I dont mean the ones you put on your pecker, I mean the rear window rubber seal on the outside of the rear door. Ive put a new one on and when I raise and lower the window the seal either gets pushed down into the door or pulled out when the window is raised, especially on the ends. Its fine when the windows wet, I suppose the water lubricates the seal a bit, but when its dry the window doesn`t seem to run smoothly through the seal. Is this a common problem, which might explain why the seal was missing in the first place, or is there a little secret to stop this happening that you could share with me?.
Regards
Tich
Regards
Tich
will let you know when I find it.
