Leaky front diff seal 😥
  • Leaky front diff seal 😥
    Hi guys
    I've changed my cv gaiters today and found another thing on my list to do lol !!
    Looks like my front diff O/S seal is leaking and possible Output or needle bearing has failed as it seems to have excessive play in the drive shaft flange
    Is there a common bearing that fails inside the diff to cause this ?
    took a brief video/pic of the problem below
    http://youtu.be/cdTD_WsSFbQ
    Just wondered who has done one of these before and anything else i should look out for would be a massive help
    just want to make sure i have everything here before i start it
    Regards glenn
    Go Hard Or Go Home
    Hi glennboy,
    Try the link below for pictures and drawings.
    Read the second link, it takes you on to possibly
    how to do it on car.
    Let us know if it works, mine has been leaking a while now.
    Hope this helps.
    https://www.google.co.uk/search?q=to...K&ved=0CCAQsAQ
    http://dahn.webcity.com.au/~toy49040...ic.php?t=16451
    Gman.
      Hi gman thanks for the reply there's some good info there, I have a seal here but didn't wanna change it if it was gonna destroy it as there's obviously bearing failure somewhere , so think I'm gonna order all the bearings and seals then can just do the lot when it's out , gonna take the diff out as then gets easier access to rebuild it in my garage , I'm back offshore next week so I'll order everything and start it next time I'm home and will let u know how I get on lol 😁
      Go Hard Or Go Home
