Evening all, as this forum is so helpful I thought I would post an idea I have just come up with.While having a sort out of the shed, came across a blown 80amp fuse and thought to my self there must be away of keeping the blown fuse in the surf and connecting a good fuse to it, save having to take the fuse box out.So came up with this, piggy back the old fuse with the new one. Once I find my other fuse box will try and mod the cover to take the extra fuse.what do you think ?
80 amp fuse quick fix
Yea if you used some really heavy duty female spade terminals that were a really tight fit against the male legs of the fuse link, then maybe that would work, but make sure they are able to take the amperage. Or you could adapt, an external inline fuse like the ones you get on high powered car stereos.www.overfab.uk
Surely by the time you've frigged about doing that, you would have changed the original fuse?Originally posted by mad o View PostGood point Surfenstein, if it was possibable to fix the piggyback fuse in to the box some how, (so it could not come loose) do you think it could work.....Mick
