Evening all, need help with a none starting surf,it was running fine apart from a small fuel leak from the fuel line at the filter,all I did was change the pipe,started it up it ran for about 2 mins then stopped.restarted the engine but would not rev, sounded like air in the system, left it running and the revs where up and down.After a few mins it seemed to clear so backed it out of the drive on to the road, drove about 100 yards and died. It is now sitting at the side of the road dead. I've replaced the filter, replaced spill valve, checked all the wireing,bypassed fuel filter, ran fuel in from a bottle hanging off the bonnet. Used half a can of easy start no joy at all.cracked open an injector line and only getting a bit of fuel out of it.One thing I did forget,a week ago changed injectors and block temp sensor,and it had been a bit of a pig to start. Any help would be great, many thanks up front Mick.
