thought this might be the easiest way to get hold of you,mate.
right, ref our conversation about body lifts.
1, i can get the 8.8 medium carbon steel heat treated bolts through work,no problem, a local company called precision profiles do them for us, generally in boxes of 100 (so 10 kits) stainless equivalent would be a morgage job,so im told.
2, delrin (polyacetal) will be slightly more than ali,and both generally cheaper to by a 'length' which is 3 mtrs give or take a bit, which would give you 4 kits of 2'' and 1 kit of 1 1/2 (at 10 per kit) this leaves a bit left over for holding, part off tool (3 mm) and facing each component.
having seen this bit of bovine fecal matter i think its a good idea........
http://www.ebay.co.uk/itm/2-Body-Lif...08798770&rt=nc
