Evening all, well just got in after a hell of a time changing the spill valve with pump still in place,not the best of jobs out in the cold,wind and rain.Had to change the valve as well as o ring as it was leaking out the top.Cleaned the little filter under the valve,took it out for a run and seems to go much better,got home lifted bonnet to check for leaks.No leaks ha ha------ not fuel anyway,water pipe decided it was time to split,job for tomorrow then. O the joys of a surf
