Hey guys,
I finally made it in!! Thanks to Admin for sorting the issue! I'm hoping you can help me though!!
I've trawled the web and I'm still at a loss!!
I have a 91 KZN130, with a 2" body lift 2" monroe suspension lift and sitting on 35x12.5 tyres! Here she is
I took it offroading over the weekend as you can see and I've developed some issues
I have 2 problems they may be connected, they may not be!!
The front diff is leaking on the drivers side I assume this is just the seal so have ordered a new one. Here's a pic.
Now I can move the shaft up and down a little, and it feels a wee bit loose.
The second is the more worrying issue!!!
I had a nasty knock/ rattle when going over anything other than perfectly smooth roads. I searched and I got the impression it may be the ARB or droplinks so I removed this and retested.
I also read about the exhaust, checked the heat shield, it was close so whipped that off and the noise is still there.
It litterally feels like something is broken/ loose and rattling about. It happens when going over anything less than perfectly flat tarmac and seems to be less slightly less apparent when conering, accerlating hard, or braking.
I ran it into my mates garage and he is going to look. Yesterday we checked 4WD operation running figure 8's on gravel and there are no nasty diff noises.
I'm scrathing my head!! Any ideas on where to start looking??
