Ive just had a Hydrogen generator fitted to my works truck this should now give me more horses more mpg and less emissions....You are at no time storing hydrogen but creating it as you drive from good ole h2o...The best bit is it is a third of the cost of installing lpg and no major modifications to the engine. I am getting 350 to a tank prior fitting this should get around 500, big savings...
HHO on diesel engines
Originally posted by mark g8awo View PostIve just had a Hydrogen generator fitted to my works truck this should now give me more horses more mpg and less emissions....You are at no time storing hydrogen but creating it as you drive from good ole h2o...The best bit is it is a third of the cost of installing lpg and no major modifications to the engine. I am getting 350 to a tank prior fitting this should get around 500, big savings...
Hi Mark, Where and how much did it cost to fit Have you a web address
regards
Andy
regards
AndyLast edited by andyverran; 10 January 2014, 21:25.
Originally posted by andyverran View Postyou can make your own, there was a kit on mine when I first got it, couple of electrode in a jar of water...
I mean 70% increase in fuel efficiency from some jam jars and knitting needles and fish tank airline fittings and the plans free on the internet, but don't let the oil companies find out or they might disappear you.
AmazeballsEat.Sleep.Surf.Repeat.
There is some doubt over whether it works..
obviosly more energy is is used to make it than you get out from burning it...only way it does any good is if the increased combustion efficency allows a greater release of energy from the fuel your already using.
I have no idea if it works, and extended test on the same vehicle over the same route with an without HHO is needed...volenteers?
Originally posted by tweak'e View Post
there is a reason why HHO threads/info has died out on forums,
its BS.
I've seen a video on YouTube where a guy proves it works.
It's just the evil oil companies and governments that don't want this information to be out there!!!
Free energy would cause the collapse of society.
Tinfoil hat anyone.
