Rusting door bottom, what can I do?
  • Rusting door bottom, what can I do?
    Evening all,
    This morning, while washing the truck, I noticed some discoloration on the bottom of the drivers door. Upon closer inspection, I found the inside bead is quite rusty & this rust is stricking through to the outside skin
    Just wondering what you'd recommend? Sand it down & jenolite it to death, then get the door re-sprayed? Or am I chasing a lost cause, now the rust is inside the skin, am I chasing a lost cause?
    James
    I would fit a tidy replacement door of the same colour.
      Now there's an idea, thanks
      Presumably the 3.0 & 2.5 gen2 versions are identical body panel wise?
        All four door 2nd gen panels are the same regardless of which engine they have. The 3.0 has a wider rubber strip along the doors though.
        Not sure what the 2.5 looks like.
