Originally posted by tashtego
View Post
Yes I have driven road based 4wd and or road based awd so I don't need to be told how good they are or can be at going around corners, my, it was almost as if they were designed to do such a thing.
It is also debatable whether front wheel drive would out perform a similar powered rear wheel drive car in the icy snowy corner and yes I know which one I would get round the corner quicker and safer in.
As you state that you drove rally cars you should be fully aware of the difference and how you can even compare a rally prepped car to a standard car is laughable, for another pointless example my bored and stroked turbo charged with NO2 Kawasaki GPZ would leave most if not all other quivering in the mix of clutch tyre and exhaust smoke but come the twisty bits my NSR would run rings around it.
But then you have probably ridden for a few works teams also so you will know what I am talking about.
I used to do The Kessel Run in under twelve parsecs so there.
You mentioned power as you seem to have a hang up about the mighty 3.0 conquering all before it especially that lowly 2.4.
If you have entered a corner carrying too much speed then you have not been reading the road correctly and no manner of combination of speed or awd or 4wd will make a blind bit of difference so it will matter less if you are in a Saxo or a Audi S8 the only difference being the cleaning and repair bill.
I would suggest that the OP could care less for steering around corners using the throttle and the rev limiter and probably just wants something he can just get in and drive.
