I'm running RCBOs across the board, so the consumer unit was never a concern. It was the wiring, which is old.
But I'll just go a head now Think I'll plumb for a 180 gas/no case semi-diyer job. Learn what I want from one before spending bigger.
If I take to it on a big scale (I don't see that being so - bit part repairs are my future) I'll wire in a dedicated line.
I hope you didn't have to pay for them RCBO's-pricey, how many is there? A split rcd board would've done if no more than 12 ways.
Your rcbo's act like an individual rcd on each circuit. As yoshie said, single phase mig supplied with 13amp plug will be fine on ring main. If it needs say a 16 or 32 amp supply then it will need it's own circuit with a 16 or 32 amp industrial type connector.
Forgot to mention one thing:- the old wiring thing you mentioned, if it's been tested while you've lived there and it tests out ok as a ring circuit then happy days.If you're not sure about it then maybe worth getting it tested. A ring circuit can function if it's not a true ring, but will not function correctly under fault or overloading conditions.
