Worth a look
Cool!
Only took them 18 months to get their new site up!Derek :
1990 Hilux Surf SSR Ltd
Originally posted by silvtr1000And if memory serves me well, you were disappointed with their springs, Del? Not quite the +2" lift they had promised?
he decided that a body lift was the permanent soloution.
Geoff.Rubblebags (Geoff).
The Explorer +2" rear springs are virtually the same length as standard - the increased ride height comes from a higher spring rate (having said that the rh one is longer than the lh coz the fuel tanks that side). I've had my ProComp setup on for 14 months now and the back end has settled a very small amount but not enough to worry about having to re-adjust the frontRoger
Originally posted by silvtr1000So wouldn't it be cheaper to get (for example) Milner's 20% stronger (I take this to mean stiffer, thus with less sag?) springs which in time will give the car the same aparrent lift as "+2"" springs?
Mark
Originally posted by rubblebagsKitesurf phill might be able to answer that one, he's had Milner springs for a while now.
Geoff.It's only a hobby!
Apologies for the late reply. I have been working the graveyard shift.
I had a measure-up this morning. Centre of the wheel hub to highest bottom edge of the wheel arch 22" with the Milner springs. So the springs have only settled by 1/4" in 3 months, despite all the caravan towing etcIt's only a hobby!
Mark
You will get no lift from Milner springs, just firmer springs. The Milner guy at Shuttleworth 4x4 show said they don't want to get involved with lifted trucks, so don't do lifted springs.
It will look lifted after the normal saggy rears, but no extra inches I'm afraid.
Got my 20% uprated springs from Milners. So far dead happy with them although they've only been on for 3/4 weeks. They have improved the ride for me considerably, but there again my 4Runner was dragging it's arse on the floor before that.
