looking true my files, i found this pic, when i replaced the original for the one of a TOYOTA LAND CRUISER vx 80 series! it fits fine, just its bigger and more fins, so i guess more cooling power
see the difference?
see the difference?
looking true my files, i found this pic, when i replaced the original for the one of a TOYOTA LAND CRUISER vx 80 series! it fits fine, just its bigger and more fins, so i guess more cooling powerthe wolf is always bigger when you are scared!!Tags: None
That's a great comparison shot J.C. I would be greatly interested to hear what our resident tech heads think about the comparative airflow characteristics and how much more CFM the new fan would shift. Would the shrouds have to be removed, and could there be any downside to that conversion ?" Time wounds all heels ".
i would say that it will be easier to fit when rad out, because it sits about
10-15 mm nearer the rad.
i never payed attention to temp difference, just did because got too many things in front, (8 inch fogs, atf cooler,...)
it never complained about temp, towing, offroading,...the wolf is always bigger when you are scared!!
Originally posted by MWS View PostThat's a great comparison shot J.C. I would be greatly interested to hear what our resident tech heads think about the comparative airflow characteristics and how much more CFM the new fan would shift. Would the shrouds have to be removed?
shrouds?
this is bolt in bolt out, no cutting or modd.
changed the plastic bit only not the rest, if that what you mean.the wolf is always bigger when you are scared!!
Originally posted by BUSHWHACKER View PostBut it's red, surely that counts for something?
Nev.
Originally posted by shokenore View PostDremmel some little 'v's into the end of the blades, that will help with some of the noise." Time wounds all heels ".
Originally posted by MWS View PostThat's interesting, Ady. I know that some fans are designed with offset blades to run more quietly, but how would little vees work ?
If you were going to do this I reckon the easiest way to stop them cracking would be to have a hole drilled in the blade tip and the v start from the hole.Eat.Sleep.Surf.Repeat.
