Hi chaps ,
I've gone through all the search threads looking for a similar problem
but not found anything !
I've had the cover etc off , greased the moving parts cogs etc, silicone sprayed
window rubbers etc .
It wont move up or down on the key switch or lever cockpit switch ,
I have the click of the solanoid in back ,
It started off as the normal problem with sticking and eventually needed a hand going up,
Is there a way of manually lifting the window ? Iv'e tried this with no luck so far !
Any ideas Guys ???? Thanks in advance for any help ! Cheers
