2nd gen hilux surf tilt/altimeter/inclinometer gauge
  • 2nd gen hilux surf tilt/altimeter/inclinometer gauge
    Hi,
    anyone knows how to adjust the tilt/inclinometer gauge of my 1990 hilux surf?
    can't adjust the two gauge and it seems it was locked. is the lock lever located on the top of 2 gauges got a connection with this and how can i unlock it?
    Thanks very much....
    Isn't there an adjuster on the front ?
      Pull yer knob out and give it a wiggle.
      or push it in... its one of the two.... iirc
      www.johnthebuilder.info
        You need a refresher course...
        Non intercooled nothing.
          I quite like refeshers, although they're not as easy to find nowadays
          What have I told you about thinking Erroll
            If you close your eyes love hearts are pretty similar?
              Originally posted by tripoltango View Post
              Hi,
              Watch the begining of this video, copy the procedure in your truck and press zero/reset on the inclinometer..
              https://www.youtube.com/watch?v=SW9lg3imdgI
                Hahahaha. Didn't need inclinometer to say that was so, so wrong. Built in, human common sense could for see that happening. Now where's my hammer.......
                  Sir Mark,
                  There was an adjuster on the front.
                  It was moving before and adjusted...but when my son touched the lock lever, it's stucked and can't adjusted anymore.
                    Many thanks Sir Bushwacker, i will follow the procedure.
                      Hahaha...just watched the video and i don't want to do it.
                      Anyway...already fixed the inclinometer/tilt gauge of the truck.
                      Thanks...
                        Any chance you could say how you fixed it? Just in case someone finds this thread. At least then there might be a conclusion
                        Glad yours is sorted
                          The problem with my tilt/inclinometer was locked.both of them doesn't moved.
                          I removed the gauges on the dash and open it up to know what's inside. I found out that it was locked causing the meters hold to it's position. Gently turn the locking mechanism counterclockwise to free the pendulum of the two gauges.
                            Refreshers
                            There is a Swizzells factory not too far from me,how many packs do you want.
