I appear to have ATF leaking from where the sump joins the rest of the vehicle.
I have cleaned and observed and think the seal needs replacing so will clean both mating areas and use some gasket paste as a seal as I do not think there is an actual seal available for the 3.0l Gen3 ?
Obviously I ill drain the ATF and replace. However, while it is clear that there are a loads od 10mm bolts that need removing but how do you get the ATF filler pipe undone or away to drop the sump pan off the body ?
Cheers + ATVB
Philip
Cheers + ATVB
Philip
