Hello everyone, I hope you are well?
Today my surf has had its first Mot since I bought it, the garage has failed it saying "Rear shock absorber has serious fluid leak". The man said the metal dish thing at the top was all corroded and he will have to cut it off.
So I want to replace as much as I can while he is doing it, as I knew the suspension was knackered anyway.
I have looked on Roughtrax and seen the rear shock absorbers, springs and the top mounting plate/metal dish things he mentioned.
Are these the 3 parts I need or are there some other bits as well?
Does the shock absorber sit inside the spring with the mounting plate on top?
Dont forget you are dealing with a complete idiot here, who knows nothing about how my surf works, although I can now give her a service myself!
Thanks for any help, Stuart.
