Morning folks,
I put the truck in for my first MOT on Thursday, and as expected she passed
There were 3 advisory items though...
Brakes Advisories: RBT Park Park brake efficiency: 11%
002 Parking brake - Your vehicle has only just met the required park brake efficiency. It would appear that the braking system requires adjustment or repair.
003/004 Offside/Nearside front brake hose slightly deteriorated.
My initial concern is the front hoses, I park the truck on a flat drive, so not expecting the truck to roll away due to the hand brake issues.
I'm going to go with the braided hose kit from Roughtrax, a couple of bottles of the DOT4 fluid, and a couple of the flexi brake retainer clips.
http://www.roughtrax4x4.com/?doc=16&cid=171&vid=1582
Doing a bit of reading on here people have mentioned the length of the braided hoses, I think they're concerned with fitting them on lifted trucks, so I don't think the length will be an issue on my non-lifted truck, can anyone confirm, or am I best giving RoughtTrax a call?
Also, others have mentioned getting new bleed nipples, any suggestions/advice on this, I didn't see them on RoughTrax, so is it a main dealer item, or can you suggest somewhere else?
Is there anything else you'd add to my list? I guess it would make sense to order stuff I might need for the handbrake but haven't investigated that as yet, open to suggestions/advice
Is 2 500ml bottles of DOT4 enough?
There's a 3rd hose included with the braided kit, which I assume is for the rear? If this is the case, is there any other rear items I'd need?
I'm also going to look to getting a specific brake pipe spanner, I assume a 10mm is the one? Found this on Halfrauds...
http://www.halfords.com/webapp/wcs/s...egoryId_165469
Got most info from this thread on here, plus will be using this as my guide
http://www.hiluxsurf.co.uk/showthrea...2brake+hose%22
Thanks in advance guys,
Rog
Rog
