for all you no i might be dyslexic and you should not be so quick to judge people without having all the facts so if you do not no the answer to my original question please keep your opinion to your self
auto box
Just so we are all at the same speed;
With the HI/LO selector all the way back you have no drive forward or reverse.
With the 4WD button pushed in you can move forward and back?
Asking as you say " All the gears work" what do you mean by this?Eat.Sleep.Surf.Repeat.
Originally posted by BUSHWHACKER View PostMistakes in grammar or punctuation can be annoying to a reader and quickly draws attention away from what is being written. These types of mistakes cause the reader to focus on the grammar instead of what is being communicated, leads them to question on how well educated the person is, and significantly reduces the impact of your message.
Proper grammar and punctuation not only helps you control the flow of writing, but also helps to accurately and effectively convey your message in the best possible way.
Just sayin'." Time wounds all heels ".
It drives when in 4 wheel drive if you switch the 4 wheel drive off it has no drive in any gear (yes With the HI/LO selector all the way back ) but i don't no if all 4 wheels are turning till i jack it up tomorrow i will let you no thanks for the help so far.
Just got it jacked up With the HI/LO selector all the way back put it in drive no wheels moving, Put it back in neutral pressed the 4x4 button put it back in drive only front wheels moving so no drive to the rear wheels at all . I have 2
Toyota surf's They both look the same when you are underneath could not see anything different hope some one can point me in the right direction thanks in advance Jeff.
Did the problem suddenly happen or did it slowly get worse before all rear drive was lost.Last edited by BUSHWHACKER; 6 April 2013, 10:32.
Originally posted by jefff View PostJust got it jacked up With the HI/LO selector all the way back put it in drive no wheels moving, Put it back in neutral pressed the 4x4 button put it back in drive only front wheels moving so no drive to the rear wheels at all . I have 2
Hope you get it sorted.
Originally posted by tashtego View PostHi Jeff, if the prop shaft is turning fine then there must be something wrong with your rear diff. You might want to take the vehicle to a garage and get them to have a good look.
We confirmation that the rear prop is actually turning first.
Thanks guys just had another look at it prop is turning so i need another rear diff what is it like changing the diff on these trucks .I have a fair bit of experiences changed auto boxes lots of engine work never touched a diff is there a how to some ware picks would be good?
