Just a quickie.....
Recently changed the head & injectors, everything back right, cam timing spot on etc & still have a slight misfire before operating temp is reached, bit of smoke & sooty injectors. Miss goes away when warm but it runs on slightly when I switch off and shudders slightly to a halt rather than switching off clean. Pump timing was not touched during head change.
Spoke to a local diesel specialist who seems convinced that, due to the miss happening when cold that it is probably electronic so my ECU needs to be plugged into a Toyota machine (or Launch 431?) to be reset or adjusted. I have no fault codes.
What is the consensus here? Are the ECU's in these trucks computer adjustable? Be good to know before I go and drop £75 +VAT per hour on getting it looked at.
Thanks in advance for any suggestions.
Ben
Ben
