Folks
I have this good guide on when and how to use 4wd, and it all make sense to me apart from L4L
When do you use L4L ? How does it differ from H4L ?
3rd Gen: The 3rd Gen Surf has a multi-mode 4wd system.
It may be used in 2wd Hi-ratio, driven by the rear wheels only, 4wd Hi-ratio with an open centre differential. 4wd Hi-ratio with the centre differential locked and 4wd Lo-Ratio with the centre differential locked.
H2: Rear wheel drive only: Normal operation, best for less wear & tear on components, best fuel economy & performance.
H4: 4 wheels driven, open centre differential: Press red button on side of 4wd selector. 4 wheel Indicator will illuminate in centre of dash when fully engaged. You may select/deselect this mode at speeds up to 100Kph. May be used anytime extra traction is desired
H4L: 4 wheels driven, centre differential locked: Move 4wd-selector lever fully back (position of button on side not important), 4 wheel Indicator and centre diff light will illuminate in centre of dash when fully engaged. You may select/deselect this mode at speeds up to 5Kph. Must only be used on loose surfaces such as mud, snow etc.
L4L: 4 wheels driven, centre differential locked, Lo-Ratio engaged: 4 wheel Indicator and centre diff light will illuminate in centre of dash when fully engaged. Select neutral on main gearbox, move 4wd selector-lever fully back, push to the right and then forwards.
Cheers + ATVB
Philip
Cheers + ATVB
Philip
