found the problem with my alternater
the big copper? wire that goes in the plastic bit with a bolt/stud thru it with a 10 mm nut was well frayed.
hope this makes sense
tried to undo nut and sheared it of below thread.
can push wire onto broken stud and dash lights go out. engine note changes slightly too.
can i fix this with spare parts. is the stud replaceable also the plastic bit broke ??????
advice needed. help
advice needed. help
