Well as the surf is now 18 years old getting a few new bits
Signed up for the rough trax discount and it was worth its money already had a discount of £12
I have just picked up a pair of impreza front seats to fit as I saw you just have to modify the side mount.
Have millers ATF coming as the gear changes are a bit sloppy and I have no record of when it was last changed if ever.
New radiator coming as the old one is on its last legs had to get a rad cap last week as it was leaking probably 18 year old.
Rear wiper blade as that is most likely the same age and does nothing
Timing belt kit as I checked it before and the belt looked ok but while the rad is out why not.
Got clear rer light lenses
Gonna delete the air con at the same time as the condenser is falling down in pieces it's so brittle plus I don't need it have a sunroof.
Got a HID kit coming as the lights are a bit dull along with LED sidelight bulbs
And a remote locking kit as I'm fed up having to put the key in the door.
That's it for this time
