hilux surf kzn wont start oil Heater fuse?
  • BioHazard
    replied
    Originally posted by ronanconway View Post
    If plunger on the top of the fuel filter housing is going stiff when i pump it what does that mean and how do i fix it?
    That's a primer ....it's goes stiff due to the pressure you have pumped into the fuel.
    Leave a comment:
  • ronanconway
    replied
    Leave a comment:
  • ronanconway
    replied
    will have a look at the home made fuse when i get back.there has been a fair bit of white smoke coming out of the car when i cold start in the morning.
    thanks for the help.
    will have a look at some of the info in this forum later when i'm not in work
    cheers Guys
    Leave a comment:
  • NiftyNev
    replied
    If it has a fuel heater there will be wiring on and around the filter housing. No fuse or relay in the engine bay fuse box usually means it's not installed.
    Do check the glow plugs and their fuse. If voltage is ok then remove all glow plugs, inspect and check for resistance. Voltage to them means nothing if they have very high resistance. Don't lose the insulators and remember the correct installed positions.
    You may need someone to help you with the glow plug removal. Be very gentle when taking them out. Old glow plugs can have a lot of carbon on the ends and may break off in the head, if not handled correctly.
    Leave a comment:
  • Apache
    replied
    Not a good sign. The whole point of the fuse is to blow in the event of a short circuit in the glow plug circuit. There's lots of current available in that circuit - certainly enough to cause smoke, fire and pain.
    You need to check for volts on your glow plug rail when you turn on ignition now then. I don't know whether you're capable of this or not, so it may be best to enlist local help if you're not - and replace the home made 'fuse' with a proper one.
    It could still always be fuel if glowplugs are functioning properly. Is the plunger on the top of the fuel filter housing going stiff when you pump it?
    Leave a comment:
  • Webbo
    replied
    Also have a look on the search function, loads of info on there glow plugs etc, these things alway pop up this time of year.
    Leave a comment:
  • Webbo
    replied
    Fuel heater ? Doubt if you have one. The Guy made up a fuse ? That sort of thing needs to be right. You know the fuse may go at any time, Have you visually inspected the fuse ?
    Leave a comment:
  • ronanconway
    replied
    i dont think its my fuse as the guy i got it off seems to have made his own fuse and stuck it in to the fuse socket :/
    have had the car 3 years now and this is the first bit of hassle i have had with it
    Leave a comment:
  • ronanconway
    replied
    is there anyway of checking if my glow plugs are ok can i use a 9v battery to see do they heat up?
    Leave a comment:
  • ronanconway
    replied
    sorry meant fuel heater
    Leave a comment:
  • Webbo
    replied
    More than likely Glow plug fuse, It protects the Glow Plugs from over current. Check it first as they are a bit pricey. Look under bonnet drivers side fuse box. Its not straight forward to change as it needs to be unbolted. Good luck..
    Leave a comment:
  • ronanconway
    replied
    glow plug fuse
    can i get them in Halfords?what exactly do glow plug fuses do they do
    thanks btw
    Leave a comment:
  • Apache
    replied
    Oil heater? Whassat then?
    More likely glow plugs / glow plug fuse.
    Leave a comment:
  • ronanconway
    started a topic hilux surf kzn wont start oil Heater fuse?
    hey every one hope this finds you well.My hilux surf 1995 wouldn't start this morning.Its a jap import.
    Every morning in the cold it takes a few goes to start (blows a few smoke rings)but today nothing.
    I was wondering if it might be the oil heater fuse? i have had a look and there is no fuse in the fuse insert.
    as i had to get a lift to work i have not been able to check to see if there is a fuel heater installed.Not that i know much about the car but i have had a look at some old posts.
    normally i put a bit of diptane into the fuel but the local shop where i get it from have been out for a few weeks will this help in anyway?
    A buddy of mine works next to halfords and has gone in to see is there a fuse for me and they have a 40amp hef559 is this any good if i have a heater installed?
