overheating
Probably for the best.Originally posted by TeaMonsta View PostApostophe removed from "your's".
I'll stop now.
You haven't been Albannached yet have you?
www.johnthebuilder.info
The trouble with this argument is some people ARE dyslexic, some didn't listen at school but lots more are just lazy.
The trouble with internet is you don't know just from reading.
The last two we can do something about, and things will be better for everyone who has to read the posts. The first is just life and you have to live with it.
Hey - at last I get to disagree with Dr Anglegrinder !
You don't have to live with dyslexia, you CAN overcome it - I won't pretend it's easy and you can never stop working at it. Both my wife and daughter are dyslexic - Jackie has just passed her NVQ3 which is pretty amazing for somebody that left school at 15 and was pretty much written off as illiterate. Katie is in the 2nd year of a BA(Hons) in Youth and Community Development which involves a huge amount of writing - obviously she has tools to help her but at the moment she's on course for a minimum of a 2/1.
bushwhacker
no idea why you sent me that link maybe i have not made myself clear but putting a bigger rad on any car will make it run cooler its as simple as that
Originally posted by BUSHWHACKER View PostExcellent intel there Carl.
Here's some more for you.....http://www.amazon.com/Dash-Style-The...N%3D0393329801
Maybe the admin could make this thread a *sticky*?
overheating problems
i do not need help with grammer the same as i dont need help with my over heating problems because i dont have any now maybe my grammer is crap but my surf engine Knowledge seems to be more than many people on this site
QUOTE=carlpppumps;781870]no idea why you sent me that link maybe i have not made myself clear but putting a bigger rad on any car will make it run cooler its as simple as that[/QUOTE]
Actually it won't if the car was operating normally before fitting the larger rad, IF the car was overheating before fitting the new rad then it may run cooler subsequently
tony
no you are wrong i fitted a new rad and heater matrix incase any shxt was in the matrix and i fitted new water pump but it still went into the red if you think about it how is a standard rad the same as the rad on a non tubo going to keep a auto turbo cool when you have the transmission oil at the bottom of the rad keeping it hot and the water from the tubo its simple it isnt why do you think so many overheat and fxck up i have had surfs for donkeys years i bought the surf with a known cracked head but it runs fine now towing or of road i have no overheating problems at allOriginally posted by TonyN View Post
Carl, I'd guess your 2.4 overheated because your rad was forked, a new 2.4 or 3.0 rad would have fixed it, the usual overheating problems on Surfs are 1/ Cracked head, 2/ Knackered viscous fan, 3/leaks from old hoses, 4/ Plugged rad, just fitting a 3.0 rad to a overheating 2.4 will only cure the last problem.
But good your's is solved.
Originally posted by carlpppumps View Posti do not need help with grammer the same as i dont need help with my over heating problems because i dont have any now maybe my grammer is crap but my surf engine Knowledge seems to be more than many people on this site
Could you tell us whats wrong with this Surf then?.....
http://www.hiluxsurf.co.uk/showthread.php?t=77993
That's the job for a fully functioning viscous fan, you have made 10 posts and have already ####ed people off, here's a suggestion, stop being an arrogant prick.Originally posted by carlpppumps View Postno you are wrong i fitted a new rad and heater matrix incase any shxt was in the matrix and i fitted new water pump but it still went into the red if you think about it how is a standard rad the same as the rad on a non tubo going to keep a auto turbo cool when you have the transmission oil at the bottom of the rad keeping it hot and the water from the tubo its simple it isnt why do you think so many overheat and fxck up i have had surfs for donkeys years i bought the surf with a known cracked head but it runs fine now towing or of road i have no overheating problems at all
Edit; why would you fit a heater matrix and water pump first? If you know as much as you say you do then you would have started with the basics, which are;
Leaks
Air lock
Thermostat
Rad cap
Viscous fan
Radiator
Waterpump.Last edited by muddle; 25 November 2012, 19:39.well, that was a bad idea!
