Hi I had no problems at all getting keys cut for my 3rd gen. Just went in to the local locksmiths. Would be happy to get it done for you but you would be without your car for a few days.
Visit all the Surfin Elkhounds at [url="http://www.malenibo.co.uk/"]www.malenibo.co.uk[/url]
Yep, same here, local key cutting place made one up, no problems.
If you want the original Toyota replacement then pop into your local Toyota dealer and order one @ £4.95 as a blank (because they can't cut it for you because they "Don't have the necessary information for an import) !!!!
You then nip along to your local locksmith who cuts the blank to match your existing key - a couple of quid.
What you don't get, of course, is the remote locking bit.
"Toyota won't let us have the software for programming imports" says my local dealer.
Cheers you lot, Rob i will pop in next time in Dumfries, i have now got a 98 blue over silver as your goodself, yellow Bosch driving lamps on front, so if ya see me give us a wave.
Iain
I'd rather have a bottle in front of me than a frontal labotomy
dumfries is a bit of a long way for me to come to get a key cut but if i'm ever up that way i'll give all blue over silver surfs a wave, it could be either of you 2.
i've had problems getting second remote key for my surf, but have just had a new immobiliser fitted that overrode original so i can now use it with just a normal cut key. if you still want remote c/l you can get a system for less than £200. A lot less than getting toyota OE fitted.
[SIZE=5]martin [/SIZE]
[B][FONT=Franklin Gothic Medium][COLOR=lime]Where Pilgrims climb may grecians fall[/COLOR][/FONT][/B]
