Well after nearly two and a half years of standing idle the truck fired into for the first time . All it took was a fresh battery and a quick squirt of easy start. I've only moved it about 10 feet up and down the driveway and had the engine idling for about 15 minutes and couldn't spot any leaks, knocks, noises, etc. Going to do oil and filters change when i get a chance. Anything else I'll need to do?
it's alive, it's alive! mwah ha ha hah
Tax, insurance, MOT, Tyre pressures, tyres - cracks/flat spots from standing, check brakes for high spot rust where the pad has been in contact with disc. Air con will stink. I'd top up the fuel now rather than running it on a little very old fuel.... depends how much you have in it.Originally posted by captain_chaos View PostWell after nearly two and a half years of standing idle the truck fired into for the first time . All it took was a fresh battery and a quick squirt of easy start. I've only moved it about 10 feet up and down the driveway and had the engine idling for about 15 minutes and couldn't spot any leaks, knocks, noises, etc. Going to do oil and filters change when i get a chance. Anything else I'll need to do?
loads more probably. Why did you park her up for so long?
www.johnthebuilder.info
Bin that ugly arsed front bumper!!Originally posted by captain_chaos View PostAnything else I'll need to do?
Welcome back.
Take it easy on the brakes for 10 mins, to clean the discs and drums, and like WR said get some decent fuel in it reasonably quickly.
Mines been parked up for almost a year, and i'm planning on returning it to the road in the next month or so (well before the threat of any snow) hopefully it will fire up as easily!
http://i1082.photobucket.com/albums/...10622-2011.jpgLast edited by s1mon; 6 October 2012, 18:49.
welcome back ....
