Garage breaks anti roll bar
  • Garage breaks anti roll bar
    Hello, took my surf down to my local garage to get them to replace ns cv boots. In the process they broke the anti roll bar, should I pay for the part or should they stump up for the cost of the part? I am assuming that there will not be much more in the way of labour to put the new one on if they are working in that area?
    Ermmm quite easy, they broke it they fix it/replace it
    My 4x4
    My choice
    Back off
      If they didn't have to right tool to remove it without breaking it and they didn't warn you before hand then its their fault 100% and the replacement part is their responsibility,
        How the feck did they break the anti rollbar???!!!
        Surely you mean the bracket?
          I disagree, 8 times out of 10 the ARB links are badly corroded break when you try and undo them, they often break just with flexing the suspension offroad.
          Its part of the cost of doing a CV, I know about it and tell people they'll probably need the links to if they break, but if you've not done one before how can you advise people?
          It's just life.
            thanks
            thanks for all your advice. Picked my surf up today from the garage all fixed, no bill yet so wait and see what they do. I use them quite a lot and their normally quite good so might forgive them!
              Was it the anti roll bar or the drop link,and they should pay
                not sure , could be the drop link, new bit that I can see is about 4 inch long and vertical? I'm no mechanic hence the garage.
                  Drop link
                  www.johnthebuilder.info
                    Originally posted by Wolfracer View Post
                    Drop link
                    Supporting lintel?
                    Sent from the iPad you "lost"
                      Originally posted by slobodan View Post
                      Supporting lintel?
                      I aint got one at all and mine hasn.t fell down yet
                        That needs trussing.
                        (no idea what I'm talking about, but I sound like a builder, don't I?)
                          Exactly like a builder...
                            ok sounds like I need to talk to my mechanic about trussing my lintel to the apex!
                              For what it's worth, as a former mechanic myself I would have phoned you when the problem became apparent and had a conversation with you about it before proceeding.
                              Realistically, I'd hope that you would pay for the part and I would fit it for free. However, as a valued customer if you refused I would wipe my mouth and put it right for free.
