Re 4wd issues
  • Re 4wd issues
    Hello all
    Recently posted about my 4wd problems and im still unable to get it going took it to a garage and they said it sounded electrical but without a wiring diagram would not be able to take it any further
    I was wondering if anyone has a diagram of the 4wd system as ive read a few posts about sticking solenoids and ADD etc but with out knowing what these bits are or where im looking im a bit stuck and not having much mechanical knowledge. but would like to have a go at this myself also does anyone have a wiring diagram as i would like to start by changing the relay under the steering column but not sure which it is.
    i used to get a click from the relay before it packed up so was wondering if this is the problem...
    many thanks swifty
    Cool Beans
    Some diagrams here......
    http://www.toyotasurf.asn.au/techsite/downloads.htm
    And here's how to delete the troublesome vacuum part of the system....
    http://www.hiluxsurf.co.uk/showthrea...ghlight=modify
      I have taken some pics of the A.D.D control systems and all relavent diagrams to help you sort your four wheel drive out. Ill see how the pics come out one here they kight be a bit small.
      Hope this helps
      Jason
        Cheers lads I've got the week off next week so ill be delving into it and sorting the bugger out.
        Many thanks for the info and help ill let you know how it pans out..
        Cool Beans
