Hi guys thanks for info on London emission zone sent off lots of pics etc to Transport for London they will send you a form to fill in and allmost by return post my Surf is now compliant , thanks again , right now to the matter in hand I have a leak in the passenger side footwell, thought at first it was the screen but have recentley had to have a new one fitted, and on close inspection there was nothing amiss, it may be poss I have been driving through too much flood water and possible entry through door rubber but cannot see where, also been told many cars have a pollen filter which sooner or later leaks help appreciated please guys , the leak is not just a trickle .
Leaks
Leaks
No sign of a leak there recenly fitted complete new arial all water tight there, also checked a grommet under the carpet in the footwell thats ok as well.Originally posted by HONEST AL View PostCheck the rubber grommet that fits around the coax from the aerial,comes through somewhere to the left of the glove box,If I remember correctly the hole is approx 10mm in diameter,if grommets missing....lots of water
They seem ok but then I am only a chippie what do I know ,will get my soninlaw to investigate further he is a mechanic , lets see how good he is ha ha . will keep you posted.Originally posted by shokenore View PostHi
It may be the heater matrix that is leaking.
Have you had a look at your coolant levels?
