comments on this item
  • comments on this item
    http://www.ebay.co.uk/itm/TOYOTA-HIL...item3f127c940c
    has anyone fitted one of these? Would it be a straightforward fit to my 2nd gen ? or should I buy a second hand one and redo the solenoid
    Shirl
    Why not just fit new contacts to your old one?
    I've never had to change an actual starter motor, in god knows how many trucks i've worked on.
      well I would Tony, but ..the garage would not do it and said I should get another starter motor ( I had the solenoid repair kit in the truck for them to do it, complete with fitting instructions)....
      Yesterday I was sitting at a petrol station after filling up and it took at least 10 go's before starting...Should the glow plugs be changed too...could this cause a starting problem.....
      Shirl
        Shirl
        Maybe this is pointing out the obvious, but there must be more than one garage in Leeds. Find one ( or even a mobile mechanic ) who will do it.
        Сви можемо
          I had starter motor issues a while back, nothing worse than the thing letting you down. I fitted new RT contact kit but still I had fault which would come and go, I put it down to some internal wiring maybe ? So as they are such an Arse to get on and off I bought a new one from RT all has been fine since. The one on Ebay for £110 del is a very good price and looks just like the RT one, they are much smaller than the originals. Also Glow plugs and starter motor are two different faults.
            the trouble is its difficult to get a garage that won't rip me off..maybe try a home mechanic...
            Thanks guys
              Thanks guys
              Have a go yourself, its not to bad a job, and there is plenty of help on here.
                maybe stating the obvious but it caught me out and made a big difference to starting, when was your fuel filter last changed
                __________________
                Back in the day Baby
                  erm.......pass....oops
                  shirl
                    Oh....I have heard members having hand injuries in the process...I daren't risk it as I might never play the piano again !!!!!!
                      Try one of these Shirl
                      http://uk.search.yahoo.com/search;_y...n+leeds&fr=sfp
                      Good Luck
                      11+ Years of Surfs .... n Faultless to a " T " is my Yota
                      Buncefield Burner
                        Shirl,
                        Take it into Station road motors at Kippax,
                        they do all my MOT's, and, the jobs I don't
                        want to do, allways do a good job for me.
                        0113 2870500
                        Gman.
                          Originally posted by GRASSMAN View Post
                          Shirl,
                          0113 2870500
                          Gman.
                          Truck is in station motors...I decided to buy the one on ebay with the advice of station motors....Problem, the mechanic says the wiring loom will not stretch to fit connection on new starter.......I had a solenoid repair kit in the truck, so they are going to repair my original starter.....what a palaver
                          Shirl
                            Shirl
                            Gman.
