lost it
  • lost it
    anyone had lost the vin plate?
    how did you managed to get a new one?
    lost the one of the 2.4 '92
    any ideas? thanks
    I'm still working on that one myself
    although from what I have read I need to go to local DVLA office with all my paperwork and they can issue a new one "eventually"
      Make your own?
      http://www.vin-plate.co.uk/any_car_van_plate.html
        Works for me
        Cheers Vince, I'd only looked at the official sites as thought that was the only way.
          cool thanks, just need to find out the rest of the details to fill it.
            Vin Plate
            Noticed mine was missing a while back,asked at the MOT station I normally use and they said as long as it was visible on chassis leg it was not a problem !
              cool got the plate, but now what numbers i stamp on??
              chassis nmbr., ok
              engine, ok
              what numbers should it type for the rest?
              i was cleaning the rear diff and i found out is an LSD,someone painted over it,
              the front i don,t know jet.
                someone?
                  Heres a picture of my old VIN tag.
                  Most of it is self exalpanatory
                  Trans=transsmission in my case auto with overdrive
                  Axle=G294 open diff G295 Ltd slip diff
                  Can't help with the colour,and trim codes other than tell you mine is black with black/dark blue interior.
                  Regards
                  Mark
                    Wow, that means I do have an LSD, I was right when I first got it spinning up both wheels on a corner! Shame is doesn't work now
                    Still Can't believe I own a Hilux
                      Regards
                      Mark
                      thanks for your answer, but this is a 2.4, so i will be different code, or...! , im wrong,...
                        Yes it will!
                        Model No=KD-LN130W (N if you have'nt got the wide body version,unlikely)
                        The rest of the letters after the model no are B/S
                        Engine No 2L-TII
