Sorry...forgot you had the two fans on the front. Did you have those running as well when you had your test drive?
replaceing the viscious fan
They did cut in, given the restricted air flow i got i guess the fan aint too bad, at best it's no better than it was with the viscious one on, anyway i think i have problems!!! Bigbobe's truck has a bl00dy great 10mm steel plate welded on the front so his is getting hotter than mineOriginally posted by Overland Tonka View PostSorry...forgot you had the two fans on the front. Did you have those running as well when you had your test drive?
