2.4 aircon fans
  • 2.4 aircon fans
    there is a hose connected to them, what is it for? air? oil? ??
    thanks
    It's just a breather for the motors.
      Blow down it to make the fans spin.
        cool that's good, so i can continue with my plan to be intercooler fan from aircon fan. thanks
            I assume you are thinking of replacing the under slung air con condensor with a intercooler and then using the original air con fans to suck air through the intercooler ?
            If your truck is a fully paid up member of the shiny club then it may work however do not even think of any off roading .
            Eat.Sleep.Surf.Repeat.
              the intercooler as in here
              and the fan underneath
                got it ready to fit, but i need to figure it out to connect the sensor is on the cooler to the fan. any of you has done it?
                thanks
                  thanks
                  What eczaklee do you intend the fan will do?
                    Hoversurf?
                      Hoversurf?
                      Back in a bit gotta clean the tea I just spat out all over the keyboard
                        suck air from the scoop, fan is under cooler of a pajero, so i want to connect the sensor of the cooler to the fan, so the fan starts when it needs
                          Originally posted by Thrifty
                          as crazy as it sounds ive actually seen this set up and know what he means. i think. so now he is adding an electric fan under the turbo cooler retro fitted under as bonnet scoop, to suck more cold air in as the temp rises. or at least thats what i understand, correct me if im wrong.
                          yeap you are right,
                          (im i getting worst with my english?? people dont get what im saying??)
                            i think the words aircon fans threw people off your meaning, you meant fans mounted under retro fitted turbo cooler. i think
                            it sound quite technical, retro...
                            doe im using only one fan of the aircon.
