At the rear of the Surf there is a 12v outlet and I was wondering if this can be utilised to charge a 85 or 110 amp deep cycle leisure battery.
Obviously it will only charge when the engine is running, but when you switch off the engine is there anything to prevent it draining back into the car system?
Is there a simple way to charge the leisure battery while driving around as it will be quicker and cheaper than buying and using a solar panel?
