Ive lost my 5th and reverse gears!!
  • Ive lost my 5th and reverse gears!!
    How weird is this, I cannot get it into reverse at all and it wont go into 5th either!!
    Now on the way home its like stirring metal porridge 1>4th gears are hard to find?
    Any thoughts on the problem
    Mark
    Low oil level, seized selecter, busted layshaft bearing, broken selecter shaft, busted synchro ring,
    dead horse in the lavatory?
    Non intercooled nothing.
      Try the gear lever bush on the top of the box.
        Clutch fluid level low - air drawn into system causing reduced clutch throw?
          Any odd noises with engine running and clutch depressed? (DMF/pressure plate collapse).
            Are the four bolts tight that hold the gear lever assembly to the top of the 'box?
              I did wonder what the smell was!!
              Thanks I will check
              Originally posted by davec170 View Post
              Clutch fluid level low - air drawn into system causing reduced clutch throw? Any odd noises with engine running and clutch depressed? (DMF/pressure plate collapse).
              The clutch is on its way out and will need replacing but no extra noise, cheers
              Thanks I will check when at the same time as looking at the bush
              Cheers guys
                Did you check the clutch fluid level?
                  Yes all good thanks
                    ok gents it seems to be the "ball unit" above the bush has broken down are there any repairs or is it a replacement unit? as it looks like factory rivet thing keeps it all together.
                    This is the diagram
                      Hello Mark. Whereabouts, other than "In a house", are you located?
                      " Time wounds all heels ".
                        changed that now!!
                        Marlow, Buckinghamshire
                          Originally posted by madcampbell View Post
                          changed that now!!
                          Hi Mark. Reason I asked, was to see if there were any g/box specialists near you, who could supply a good used replacement stick and turret. Yours may be the same as a Mk3 Hilux 4x4. No one comes to mind for 4x4 in Bucks, but you could try D Beaumont g/boxes in West Yorks, or Intergear int the West Mids. Equicar in Wolverhampton are a good 4x4 breakers, and may have used 4Runner boxes. Check the price, new from Toyota, first, though, because they may be cheap anyway....Good luck.....Mick.
                            Thanks Mick I think TonyN has come up trumps again!! appreciated your help
                            Mark
