Originally posted by wolfracer
View Post
Wanted adjustable drop plate hitch
Hitch
Hi hitch available from Towsure, they have a number of stores in the country and you can order one on line.
Should really use a four bolt towbar, not sure of legal requirements but you could end up putting a high twist torque on your tow bar. Don't forget the hitch will also add an amount of movement as the 19mm pins will move.
I tried to explain that earlier referring to it as leverage on the towbar.Originally posted by Burian View PostHi hitch available from Towsure, they have a number of stores in the country and you can order one on line.
But apparently it fell on deaf ears and we ended up discussing how many lug nuts an Australian Vauxhall has..
Hitch ordered. The trailer distributor said the tow ball should ideally be 16.5" high. Mine's about 24", so need to drop it about 7.5"...
fingers crossed
www.johnthebuilder.info
Sorry for not acknowledging all your post guys... please forgive my ignorance.Originally posted by BUSHWHACKER View PostI tried to explain that earlier referring to it as leverage on the towbar.
But apparently it fell on deaf ears and we ended up discussing how many lug nuts an Australian Vauxhall has.."B.A." Baracus: "Talk to me, talk sense so I can talk back. Not all this jibberjabber like breaking the peace and all that."
Don't take the 16.5" as gospel - it'll depend on the trailer, the load and the sag on the Surf. Set it so that it's slightly nose down empty and loaded - if it's nose up it'll try to take off at speed ... Obviously it won't succeed but the handling will be 'interesting' !
