I recently removed the rotten rear quarter bumpers with the view to fitting new ones. However i like the look of my truck without them. If i leave them off will it pass or fail the mot?
MOT question
mot
think you will find with a bit more research that bumpers are not required however, must be fitted if required, unless al fittings, brackets are removed and you cannot injure a person when you run them over, are surfs are governed by a twenty year old law ish but you can use expanding foam and cut as long as long as no sharp edges to cut someone you run over for mot. WARNING DO NOT TRY RUNNING SOMEONE OVER IT MAKES A MESS WITH SMOOTH BUMPERS
I think as long as there are no protruding sharp edges you are fine, the only sharpish edges left on mine after removing the bumper are well underneath where the bottom edge bolts up to the body. To be honest if someone finds themselves under my truck when I`m driving, sharp edges are the least of their concerns
Thanks gents. I will find a way to tidy up the main bumper left and right ends. Expanding foam may work,fiberglass or simple wooden blocks,got to be a simple way. I really never liked the look of the quarter bumpers, far better without them. I found a bit of corrosion on the nearside with the bumper removed. Cleaned etc and fiberglassed it, looks fine now.The offside is perfect. By the way the bolts were badly rusted, most of them sheared when i tried to remove them.
