Hello
I was looking at temperature gauges to fit to my LN130, as want to have a better idea of temps rather than the standard gauge, when I came accross the engine watchdog - www.enginewatchdog.com .
Anyone had experience of these?
They attach to the cylinder head via an existing bolt and then give you a digital readout of the temp, but the bit I liked was they beep at you if they go over a certain level ( you set this)
Not sure if it is a good idea or if I should stich with a gauge, certainly cheaper.
Tim
Tim
