i had being last 3 hours outside trying to put to work the #### window changed every single fuse i could find, new relay box (big one behind panel on the back)
new wiring loom on the door, new switch on the centre console tested the motor, it works, when all connected window goes down not up with the key, switch it doesn't do anything.
it started a few days ago centre console switch not working, but ok with the key
now only goes down, is it any more relay somewhere?
