My steering recall update
Just got my Surf back from the dealers.
Will have a look tomorrow at the new relay rod in the daylight.
It has been cleaned inside and out.
Now they want £1708.43 off me for;
Gearbox mount split £507.55
Oil filter on gearbox due £292.06
Low oil top up 1 ltr
Rear crank seal leaking £406.12
Brake fluid
Coolant service change due £89.45
Osr stabiliser bush missing £10.49
Osr stabiliser bracket broke £ 194.70
Osf Cv boot split £208.02
Well all I will say is "Its gonna' be a lean Christmas in the Dragon household this year"Eat.Sleep.Surf.Repeat.
Ooops, have you just written off your surf... hope you've got your no claims protected?
www.johnthebuilder.info
Now they want £1708.43 B/S!off me for;
Gearbox mount split £507.55 B/S!
Oil filter on gearbox due £292.06 B/S!
Rear crank seal leaking £406.12 B/S!
Brake fluid
Coolant service change due £89.45 B/S!
Osr stabiliser bracket broke £ 194.70 B/S!
Osf Cv boot split £208.02 B/S!
Which dealer so I can put the word out they are robbing b*****ds?
Originally posted by BUSHWHACKER View PostWhich dealer so I can put the word out they are robbing b*****ds?
G/box mount may well be "split" I'm sure though the rubber is in the condition I would expect it to be for being 20 years old.
If the G/box filter is as dirty as the pics you posted then I will leave as is.
Low oil ? mweh ?
Rear crank seal leaking more likely the rear rocker cover seal dribbling down the back of the block.
Brake fluid ALL the brake fluid was replaced when I very recently replaced out the corroded brake lines in front of rear wheel .
Coolant change ? hell the only thing I have seen recently that was greener was Shrek.
Rear osr bush and bracket missing guilty as charged (new bracket from roughtrax waiting to to be fitted Saturday),and that only got damaged after a recent trip over The Plains.
IF I had just been Joe Public then yes I would have been robbed ,but with the help of this site and it's members I knew that I can rely on for so so much.So many many thanks to All of you who have given me very good advice over the years.Eat.Sleep.Surf.Repeat.
You can tell they were just thinking up prices by the unusual amounts.
How do they know the history of the coolant changes, it's an import!
The transmission filter will last the life of the truck and should never need replacing or even cleaning. The solenoids or clutch bands will pack up before the filter will.
I replaced a (http://www.roughtrax4x4.com/?doc=16&cid=163&vid=828) on Lexurf VII, took all of 15 mins FFS!
Originally posted by shokenore View Post15 mins?
I assume jack up to take weight of g/box undo mount and replace with new.
So £36 for parts and £471 for 15 mins labour seems about right,Trading Standards springs to mind
Bolt the new mount to the transmission first, then to the crossmember.
letter
just recieved a letter from toyota this morning informing me my local dealer will be contacting me to arrange an appointment to carry out the work.
pleased i got the s/h engine in and running last saturday.
it,s only been 4 weeks since i contacted the customer services .
result!!! .
Originally posted by BUSHWHACKER View PostYup, take the weight of the transmission using a jack and block of wood under the sump or under the transfer box, 12mm & 14mm sockets and an extension bar is needed to get at the bolts on the transmission side of the mount.
I will have a look at the mount when I am refitting the arb bush.Eat.Sleep.Surf.Repeat.
