Can anybody give me the dimensions in mm,of the rev. mirror to edge of wing/bonnet and the distance from the front leading edge/headlamp to the rubber edge of the mirror seal.Fitting a rev mirror.Many thanks in anticipation,cheers.
Reversing mirror,help!
Duncan, A bit of a confusing post ??? Do you mean the little parking mirror on the left hand side front wing of the truck, this looks down to align kerbs and such like. The 3rd Gen surfs (some of , not all) are fitted with a Reversing mirror which pops down with the press of a button and is purely for reversing up to things.
Andy
Originally posted by Andy WDuncan, A bit of a confusing post ??? Do you mean the little parking mirror on the left hand side front wing of the truck, this looks down to align kerbs and such like. The 3rd Gen surfs (some of , not all) are fitted with a Reversing mirror which pops down with the press of a button and is purely for reversing up to things.
Andy
And I use the one inside as well, wait for tow bar to go bump and reversing completeSay not always what you know, but always know what you say.
My 4x4
My choice
Back off
Its the small one at the leading edge of the l/wing.'Malinebo' kindly gave me one(mirror that is),so I've sprayed it and now I'm looking at fixing it,I can gauge approx. where it goes,but what exactly does it focus on?(rear wheel,middle or what).
Cheers Koi,I've ordered the tow bar if all else fails!
CURRY-ER
In all honesty Duncan, if your Surf hasn't got one fitted, I wouldn't bother fitting one, as it is no use whatsoever.Originally posted by DuncanIts the small one at the leading edge of the l/wing.'Malinebo' kindly gave me one(mirror that is),so I've sprayed it and now I'm looking at fixing it,I can gauge approx. where it goes,but what exactly does it focus on?(rear wheel,middle or what).
Pete
Actually I disagree, I used to think they were useless but when you get used to using it, it's very good for reversing into tight parking spaces in a carpark. Even better when you still have the side steps on as it stops you hitting things with them when you can't see them.Originally posted by Stephen ParkinsonI've never used it since I've owned my surf... if it ain't there i see no point in adding it
just my 2p
just my 2p
I find it very handy for hanging my handbag on so I got two hands free for rummaging for keys, mobile, purse etc....
(oh come on, some girlie had to say it..!!)Had enough... going to live in Spain....
trouble is helen most of the guys on here wont admit to being a girlieOriginally posted by HelenI find it very handy for hanging my handbag on so I got two hands free for rummaging for keys, mobile, purse etc....
Enjoying Life after Cancer
Pops
Measurements are 33mm from inside edge of wing to outside edge of rubber at the rear of the mirror and 80mm from front of the wing (at the most forward part) to the front edge of the rubber on the mirror seal.Originally posted by DuncanCan anybody give me the dimensions in mm,of the rev. mirror to edge of wing/bonnet and the distance from the front leading edge/headlamp to the rubber edge of the mirror seal.Fitting a rev mirror.Many thanks in anticipation,cheers.
Originally posted by luckyMeasurements are 33mm from inside edge of wing to outside edge of rubber at the rear of the mirror and 80mm from front of the wing (at the most forward part) to the front edge of the rubber on the mirror seal.
Bless..... you just been out and done that ??? What a good bloke...Had enough... going to live in Spain....
