Completed a 2" body lift this weekend. All went well until I went to asda to fill up.
Opened the fuel panel and the filler cap was stuck in the hole. Tried unscrewing it and the top part of the cap came off and other part was still screwed in to the pipe. Eventually got that out and the filler pipe has pulled through the housing.
When I did the lift I loosened the two mounting bolts for the filler pipe thinking this would give some slack. Maybe I was wrong!!
Anyway I'm liking the new improved view from the truck but could do with some advice as to how to fix this properly without making things worse.
