2" front lift - Ball Joint Spacers
  • 2" front lift - Ball Joint Spacers
    Saw this on ebay and thought I'd point it out - Good value!
    http://www.ebay.co.uk/itm/toyota-hil...item3a69d1222f
    Don't let him near your wife tho'
    Sent from the iPad you "lost"
      Hmmm, tempting. I need some.
      Anyone doing them any cheaper on here?
      How does fitting these affect where the lower arm sits with regard to bump stops, as mine currently maxed out and touching...
      www.johnthebuilder.info
        Should drop the lower arm by two inches and therefore the bump stop will be that much further away from touching on full compression.
        Out of interest what bull bar is that on your avatar?
          Cool, thanks.
          A Bar is the standard one. It was missing the shiney bits so took off the cross member and replaced it with angle iron, covered with ally chequer plate.
          does the job!
          here's a bigger pic...
            Cheers Bud Thought it looked familiar Im thinking of tinkering with a standard one to replace my massive aftermarket one.
              You should get your facts right Instead of jumping in with your wooden spoon ......It's not who you think it is ...... That's Neil the guy who owned Outrageous
                Who gives a sh1t.
                And stop following me around you homo.
                  Originally posted by Wolfracer View Post
                  Cool, thanks.
                  does the job!
                  When I grew up I hope my truck looks like that
                  Eat.Sleep.Surf.Repeat.
                    Who gives a sh1t.
                    The facts would only spoil a good punchline huh?
                    Bio's better behind you, then you get to throw mud at him while recovering him.....
                      Yeah if you follow him. it's like following a heavy horse with the size of clods that get thrown at your windscreen.
                      Gone from 4x4 to 1x2
                        You're far better off with Bio throwing clods at you than with him dropping his guts ...
