Do you mean tht when you leave and come back you are automatically logged back in?
There is a cookie in the browser that does this for you. If you click on the logout button underneath the banner pics then this should remove the cookie.
Rich.
You may clear all your cookies by clicking HERE . If you return to the main index page via the link provided and you are still logged in, you may have to remove your cookies manually.
Here are the instructions for Internet Explorer 5 on Windows:
1. Close all Internet Explorer windows.
2. Click the "Start" button.
3. Move up to "Find" and click "Files or Folders" from the menu that appears.
4. In the new window that appears, in the "containing text" field, type in the domain name of the board without the "http://" or "www." part. For example, if the board's address was "http://www.vbulletin.com/forum/index.php", I would type in "vbulletin.com" (without the quotes)
5. In the "look in" box, type in "C:\Windows\Cookies\" (without the quotes) and press "Find Now"
6. After it has finished searching, highlight all files (click a file, then press CTRL+A) and delete them (press the "delete" key or SHIFT+DEL)
Your cookies should now be removed. You may want to restart the computer and revisit the board to be sure.
Above from the FAQ link, seems a lot off effort. I'd just leave it logged in. Unless you have others using the PC who you don't want posting on here in your name. (drunken friends have been know start stuff this way! )
it works anyway clicking on it turns you into a guest
[size=5][/size]
Bet Tony's the "guest" that won't leave - even at 5am when the whole household is asleep on the sofa, he's still there fiddling with your cd's, helping himself to your scotch, farting & blaming the dogs........ He only came over for lunch !!!!!!!! Be Warned !!!!!!!!
Jim
