there is the mysterious clunking from the front, the rattle over bumps, the knocking etc etc
then the squealing starts - read up and worked out its the brake pad wear metal tab thingymebobs
so i order up a set of pads from roughtrax, they arrive
tonight plan - simple, swap pads and get the squealing gone..
Simple job??
Nope!!
both calipers, both sides are seized
no wonder I've had rubbish brakes for the last while
the outer pistons all ok, push bak in fine, but the inner (closest to engine) are fully seized - not 1, not 2, but all 4 pistons
1 I've managed to free up a little by following some advice here of loads of WD40 sprayed under the seal and get someone to pump the pedal, it just about extended, but I cannot get it back in..
so whats next - call it a day with the truck and break it
splash out on getting 2 new calipers for something else just to go wrong??
is it really worth buying second hand calipers??
anyway - thats that rant done!!
Simple job??
Nope!!
