@bushwhacker
  • @bushwhacker
    found the correct ecu pin out diagram for lexurf V - ill connect the digital speed sensor output to pin 12 tomorrow and let you know if it works
    should give me 2 speed sensors like the original lexus set up
    Excellent!
    I'm still trying to send those diagrams to you. but our scanner won't scan.
    It's going in the bin next week, we've had it nine years, time for a new one.
      i just got a new one - hp deskjet - 41 euros.
      printer and scanner - works fine. it was cheaper to buy that than buy ink for the old one
        speed sensor connected and seems to work. ill drive it around a bit and see how it goes.
        i have a sneaky suspicion the lexus speed sensor is breaking down intermittently when it gets hot.
        have you ever tried running a lexurf on the speedo signal alone vince. bear in mind mine is a signal source from the surf speed sensor on the t-case through the digital dash with a dedicated ecu out signal.
