Hi, i have almost had my 2.4 surf for a year. Two weeks ago the RAC sent it to a garage with a suspected head gasket problem. Since then i have had the gasket replaced, the timing belt replaced, the water pump replaced and told the head needed skimming to get the gasket to seal properly. On sending the head away i have been told that it is cracked internally. Am i just throwing money away now or is it worth sticking with it and getting it repaired. My main concern is that my gearbox can sometimes play up and not go into reverse, if this goes once head problem is fixed, then i am broke and unable to fix it further. Other problems i have are not working passenger front and driver rear window (told this is a contact switch problem), A/C never worked since bought it, back window wont work as light comes on to say door is open (WD40 fixes this for about a month) I really love this heap of truck and really want to be told she is worth it. anyone who can advise or offer help would be most appreciated. I am evesham based. Thank you Also the central locking doesn't work as the key wont turn fully only enough to unlock the drivers door.
